Completely replace head unit with bluetooth
  • 2
Hello, I want to completely remove my head unit and just use bluetooth as a method for:
  • Audio control
  • Answering phone calls
  • Steering wheel controls
I've seen SteerBlue by NAV-TV which allows me integrate a steering wheel switch adapter with my phone through bluetooth, but no where on it does it mention being able to answer phone calls? Does the pause/play functionality answer phone calls (the mode/source button used as pause play in a G35)? Are there any other techniques, parts, ideas? I'll be using a double den blank cover to mount my phone with a magnet. I will have an optional cord for charging that doesn't integrate with the audio system.
it's b/c it would have to be programmed through whatever steering wheel control unit you use.
It seems to connect as a "Clarion" to this device: Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
The manual is here: Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
On the table, it says you can program a send/end key.... as I understand at least. So with this and the SteerBlue, could I then program my mode or power button on my car steering wheel to answer / end phone calls? I'm not too sure because if you look here:
https://navtv.com/media/products_file/2015/01/12/SteerBlue_Manual_rB5.pdf
It shows that there is no button for answering phone calls....
SWC to SteerBlue:
VOLUME + : VOLUME +
VOLUME - : VOLUME -
TRACK + : TRACK +
TRACK - : TRACK -
SOURCE/MODE : PAUSE/PLAY
MUTE : MUTE
BAND : VOICE COMMAND
END : HOME
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
659
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
4
You don't have to but with the exception of what is usually high end car audio companies and home audio drivers it can be hard to find just the...
6
147
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
550
ryantrip
ryantrip
San Fransisco, CA
ryantrip
1aespinoza
    May 19, 2024
1aespinoza
    May 19, 2024
