Component amp
  • 4
Force-fed
Just got the hertz esk comps for the front of my car, 75w rms. i was looking at the focal solid2 and solid4 amps. The s2 puts out 75w rms x2, would this be enough? Or should i get the s4 and bridged its 200w x2. Woofers has a pretty good deal on both right now, $150, and $200. Any other amps to look at in that range? Only needed to run front comps, no rears, subs on its own mono. Thanks
I would say you probably can't go wrong with Focal. I'm running their PS165 series components in my doors and I love em. Although I'm running mine off an AQ 200.2. But I guess it will come down to what type of amp sound you like better. The focal solid series are a class A/B amp. My AQ is a full range Class D.
Before getting my AQ amp I was running my front's off an Audison LrX 5.1K which was a Class A/B for fronts and Class D for sub. Comparing the two amps I found that my mids/highs (1.5-2khz and 12khz) were a little pitchy on the class A/B at higher volumes and had to EQ out some of those frequencies a bit to make it less fatiguing on my ears. Whereas with my AQ (Class D) I don't have that problem. At the same volume levels I can leave my EQ on the deck flat and the speakers don't bother me at all anymore (unless I crank it up a few more notches haha). And I find that the sound seems a little "fuller" and more detailed than before. And going from an Audison to an AQ that's saying something.
Some people say they notice no difference between Class A/B amps and Full Range Class D, but i certainly did. Also I believe Class D amps are alot more efficient than A/B.
Sorry for the long winded speech, just figured my recent experience might help you.
It's not a Focal amp, but I'm running a special this month on a 2-channel amp rated for 115W x 2. It would save you a bit of money and it's an excellent budget amp, full range Class D by Precision Power.
WTF??????Is that made by PPI??
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
978
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
Force-fed
Force-fed
Upstate, NY
audiobaun
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
