da12b 10+ year member
I read that if you're using a 4 ga power cable it should have a max fuse rating of 125A. I also heard that you should fuse the power cable according to the amp fuse rating. Eg. my amp has (3) 25 amp fuses, total 75 amps. I have a 60 amp AGU inline fuse within 18 in. of the battery. Is the correct? I'm going to change the "BIG 3" also. I have changed the battery neg. to chassie and chassie to engine with a 4 ga cable and it has helped a bit.
Let me know of your opinion on the power cable fuse. (1) Fused for the cable or (2) fused for the amp.
