Correct Components For System?
ayyjay72
I'm about to majorly upgrade my car audio system and I wanted to make sure everything I'm about to get is compatible and my setup will work properly.
Header - Kenwood KDC-255U (2-channel)
Front Speakers x2 - Kenwood KFC-P709PS (80 watt RMS)
Rear Speakers x2 - Kenwood KFC-415C (55 watt RMS)
Amp for Speakers - Kenwood KAC-2404S (4-channel; 40 watts RMS x4)
Subwoofers x2 - Kenwood KFC-W3013PS (400 watt RMS; 4 ohms)
Amp for Subwoofers - Kenwood KAC-5001PS (mono; 300 watts RMS x1 at 4 ohms; 500 watts x1 at 2 ohms)
Planning to hook both amps up to the header, use the 4-channel amp for the four speakers and use the mono amp for the two subs.
Will using one header channel for each amp work? Will a mono amp work with two subs?
Thanks for any help guys.
Amp for Speakers - Kenwood KAC-2404S (4-channel)
Amp for Subwoofers - Kenwood KAC-5001PS (mono)
That head unit only has 2 preouts, one for front and one for rear, or one
For front and one for sub... To run all four channels of the kac-2404s you would need to get a RCA splitter (maybe?) anyways... Something to plug your right and left channel into comimg off of the front preout of radio so you would have 4 inputs (front right, front left, rear left, and rear right) for the 4 channel... Yes you can wire both subs to the mono amp. Wire the subs in series or parallel.
That was my main concern with the head unit. Would a 5-channel header work better or be more efficient?
3 channel (3 preouts) would be exactly what you needed... The 2 would work, but you'd have more versatility with a 3... Such as fading and balance! I just got a factory refurbished kenwood kdc-x496 off crutchfield for 109.00! That has 3 channels and it's also 4 volt preout which would let you be able to not turn the gain up as high on the amps to get the same out put as the other headunit (kdc-255u)
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
797
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
ayyjay72
ayyjay72
Santa Rosa, CA
bowhunter
