Correct settings for metal? On mid-high setup with tons of settings. JVC
  • 1
sneykinko
UK
Hi. I've got JVC KD-T905BTS. I've bought it from US after reading couple reviews and it also has tons of settings.
I've got Ground Zero GZIF6503X on front which I love. And newer version on the back shelf.
They're iridium range. And they should handle a lot.
No amp. No sub.
Stereo has mosfet power though...
But I'm unable to set proper sound from it.
I just wanna ask someone skilled what to set and what to avoid?
There are 3xEQ - easy, preset and pro.
I didn't play with pro so far.
Presets also aren't very good.
Then there is loudness, bass boost etc. Also speakers size settings etc.
There's a short video of mostly all functions:
Well... It sounds a bit too flat to me, regardless any settings I've tried...
It's loud. It can deliver great amount of bass too... I just need the proper settings. Oh yes... I'm listening to rock / metal...
Thanks to everyone who had time to read this.
I'll update later if I'll get something more useful about unit later...
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
613
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
420
The intention of the eq is to create a flat curve if you have peaks and nulls. If you are competing for sq, try to get the sound as flat as...
5
427
sneykinko
sneykinko
UK
sneykinko
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
