Couple amps
350zkid
1) Kicker KX500.2
2) Kicker ZX460
3) Kove Audio Reference zx500
4) Planet Audio BB150.4
5) Visonik v4000xd
1) works 10/10, looks 7.5/10
2) works 10/10, looks 9/10
3) works 10/10, looks 6/10
4) works 10/10, looks 6/10
5) works 10/10, looks 8/10
1) $95 shipped
2) $105 shipped
3) $90 shipped
4) $100 shipped
5) $250 shipped
USPS
Might be interested in the visonik if it was installed correctly. What type of electrical did you run this amp on ?
Wasn't ran by me, I just made sure it worked.
---------- Post added at 01:53 AM ---------- Previous post was at 01:53 AM ----------
No sir, no trades
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
448
572
350zkid
350zkid
St. Petersburg, FL
350zkid
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
