couple dual battery questions.
  • 4
rebelfromva
VA
Soon I will be running an aq2200 and t400.4. Car is 09 cobalt stock battery and no big 3 right now. My battery is already ib the trunk. What additional battery would be good for this setup(close to 150 or less). Will be running fosgate 0 gauge on everything. Are fuses required between batteries(what size)? Im sure Im forgetying something right now.
Also, what kind of strippers do yall use for 0 gauge. Cut the **** out of my hand the otherday with mine which are basically only ment for speaker wire
just use short 0awg wire to connect the positive and negatives together on the batt in parallel like you would a sub or just ground the second batt and run just a positive run. i use the same cutters for 0awg as i do for 16awg speaker wire. but i use a set of klein wire crimpers with the cutting tip. any good sealed group 31 batt will help u i personally like xs power and northstar batts but they are quite pricey. look on sonicelectronix.com and pic the biggest u can get for your money dont get a capacitor or some hybrid batt that would be a waste of money
Dont use caps. But thanks for the help was thinking about a deep cycle or just one with same specs as mine but not sure if itll be enough to feed both amps
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
528
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
698
rebelfromva
rebelfromva
VA
bubbagumper6
