Couple questions.
  • 2
stay_high
Florida
Hey everyone, i have a couple questions.
1. How do you properly seal a 6.5 component speaker to the door? My car (08 ford focus sedan) has 6x8 speaker openings. I made my own adapters out of mdf then added thick weather stripping foam between the door and the adapter, the adapter and the speaker, and the speaker and the door panel. Screwed everything down tight and what not but for some reason i am still getting a lot of cancellation and rattling on mid-bass notes.
2. My amp seems to be clipping all the time. Like i have the gain just past quarter way up and i still seem to be getting clipping/distortion with HU volume on 35/50. Everything is wired right (got the approval of this site.) good ground good RCA's from HU everything but it sounds like it still like...constantly sends out a clipped signal. Got the amp used could it be damaged or something?
My setup: ID CTX 6.5c's on a kicker zx550.2.
what exactly is rattling? Probably need to do some deadening.
If you're getting cancellation you can try wiring one of the mids out of phase to see if that helps...
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
548
stay_high
stay_high
Florida
mlstrass
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
