Craigslist Autotek Amp
  • 4
i actually lol'd on that one. it says "AUDOTEK" which is definitely not "Autotek", but a comical rip-off of the name. looks like just another low-end amp. likely 650rms@14.4v at most. probably would see much less power, though.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
243
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
452
DoesDad
DoesDad
Tulsa, OK
DoesDad
Decebal
    Jun 10, 2024
