crazy popping action
  • 2
hellabent
Dont know if this is a ground loop or not but... I have a pioneer h/u, 2 punch 800s. I recently had to change my fuse and fuse holder under the hood due to it melting together. So I replaced it and now when I turn the system on and off it has a loud popping and i can hear a high pitched noise. Then once I crank the engine it has a very loud engine noise. I have checked all grounds and all are bolted to thick metal. This only happens when i have the rcas from the head unit plugged into the amps. I can take an ipod and plug it into the amp for mids and highs and it works fine. Every thing was working fine untill i changed the Fuse holder......Any help would be great as ive been going around and around with this problem. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Will do...thanks. Why does this problem just out of the blue happen tho....system worked fine for a few years. Did i beat the **** out of it?
Ive seen plenty of these cars with ten inch sub/ subs inverted/facing up and ported to the rear.. even a single 12
673
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
12
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
564
Wow that is very very odd. Could be the wiring harness from them. Check the wires and possibly reground the stereo to another bolt in back of the...
13
Maybe your amp gain is set too high, or wasn't set properly with the head units volume adjusted properly prior to setting the gain since you...
10
hellabent
hellabent
mob town
hellabent
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
