Crimpers/ strippers..
I use a chisel and a hammer...lol for 0awg...to cut and crimp..
for 4awg, a bolt cutter for cutting, hammer for crimping...etc..
But as above I use a Xacto knife for the stripping...
crimpers are low lifes that waste money on stupid ****
strippers are girls without souls.....
strip the wire with a sharp knife, and crimp with a hammer and the ground //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
razor to strip. 6 dollar torch from harbor freight and solder to make the connection. ONLY way to get a GOOD connection and it doesn't take any kind of physical activity lol
i use a knife or razor blade, and a big set of vise grips to crimp. if the connector is closed i will just melt some solder inside and shove the wire in without crimping.
For speaker wire
Razor knife for power wire.
Vice grips for crimping.
I'm interested in how you people solder them without melting the casing off of the wire. I tried with my little 20w iron and some tiny electronics solder, but that was taking absolutely forever, so I switched over to the propane torch and the bigger solder, and I was melting the casing off of the wire...
miker
miker
Wayzata, MN
94Mazda626
