Crossover help. Upgrade with stock head unit
  • 1
Maggs
CarAudio.com Newbie
I have a 2009 Peugeot 207 and wish to upgrade the stock speakers as they are lacking quality and sound a bit tinny.
I want to keep things as basic as possible so don’t want to be adding an amp, although this may be a possibility in the future.
I want to keep the stock head unit which is an RD45 which from what I can find has 4x45W channels at 4ohms. I like the stock look but mainly it controls the clock and lots of the features so I don’t want to be messing with adaptors and losing functions.
There is currently a stock 6.5” speaker in all 4 doors and 2 tweeters on the dash. I would prefer to get components for the front and replace the dash tweeters but the crossovers are causing me concern. I don’t really want to run the wires through door wire rubber if I can avoid it as I can remember it being a pain in previous cars and I now have issues with my hands.
The stock tweeter currently has a capacitor soldered to it which I believe is to filter out the lower frequencies.
- So my question is - can I install the crossovers on the doors for the door speakers and just use a capacitor on the tweeters? Or can I add a second crossover on the stock tweeter connection which I am guessing is connected to the same channel as the fronts? Or would I be better off getting coaxials for the front and unplugging the stock tweets all together? Or just man up and run the wires from the crossover in the door to the tweeter housings?
Advice would be much appreciated.
Thanks.
There's definitely quite a few that can give a better answer, but IMO, it's (1) 8" sub. It's supposed to be quicky and jabby, not a power...
7
For the front and rear speakers set the high-pass filter around 80-120 hz depending on what sounds better with over driving the speakers (you'll...
907
Agreed. I was actually thinking of building a 3-way passive and I compared the cost to a Dayton DSP and it makes no sense to go passive.
10
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
322
Maggs
CarAudio.com Newbie
Maggs
Maggs
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
