Crossover, tweeter, or amp problem?
  • 2
Mills561
BURR
One of my component speakers (CDT Audio CL-60) is cutting in and out at low volumes. The woofer plays continuously, but the tweeter does not. From about 0-20 it doesn't play at all; 21-30 it cuts in and out; 31-35 it plays fine. I've checked the connections at the amplifier multiple times and it seems to be fine. Have not yet checked the connections on the speaker because I doubt that is the problem. It sounds like it could only be the crossover that is the problem... Does this sound right? Is there anything I would be able to do to the crossover to affect the output or am I pretty much ****ed?
And an off topic question- is bridging component speakers a good/acceptable idea? I'm working with a 4 ch Hifonics amp that puts out 50x4@4ohm, but currently using just two of the channels. I feel like I could get more out of the highs in my system. I've got the hz set pretty high so there's no bass going to the woofer, so I'm not too worried about overpowering them.
Sounds like you've got a loose connection anywhere from the actual crossover to the actual tweeter. Check your connections on those.
No problem with bridging channels.
Thanks for the reply. I was hoping not to have to check out the speaker connections because my door panel is a ***** to get off. But I'll have to do that when I get the down time.
How exactly do you go about bridging the channels? Noob question, sorry!
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
464
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
9
Mills561
BURR
Mills561
Palm Beach, Florida
Mills561
