cubic feet of a box
  • 3
beat-down69
I started on my box build today and have 1/2 of it done.
The box demensions are
54inch width
17inch depth
20inch height
About a month ago I went on the12volt.com website and went to box calculators and according to that it said the cubic sq footage of my box was 7.69 well i went back just about 20 min ago and punched inthe same demesions and now it says 8.71 So i am wondering what the deal is. How do i find the true cubic foot of my box.
Any and all help will be greatly apreciated
Multiply the L X W X H (in inches) then divide by 1728.
Dont forget to figure in the thickness of the MDF.. if your using 3/4" MDF, youd multiply...
52.5 x 15.5 x 18.5 then divide by 1728. Also dont forget to figure in your port/driver displacement as well as whatever bracing. 8.71 is correct...
ok thanks this last time that i punched it in it came up with 8.71 and yes im using 3/4 mdf. The sub displacement is .19 each so for both of them they are .38 I am going to use two 8 inch aeroports and tune it around 55
8.71 ft^3 looks correct for a 3/4" thick box with the outside dimensions you supplied. If the box was ~1 3/16" thick, it would be 7.69 ft^3. This is excluding cleats, supports, port assemblies, and the speakers themselves
I wish there was a place around here that i could of gotten thicker material but 3/4 was the best i can find. LOL It should be fine though. Thanks for your help
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
I’m finding new songs that weren’t hitting on my DD712. Bass reflex 4order. The bandpass is selective to 70+ songs and plays them better than...
If you use the crossover in the head unit, then you aren't sending that part of the signal to the amp. (Whether or not that allows a more narrow...
990
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
beat-down69
beat-down69
Buffalo, KY
beat-down69
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
