Cup terminal wiring connector question
  • 3
Either one work but I do the ring terminal on the bolt if I can. Especially with dual voice coil, makes it a lot easier to wire up both that way. Just don't Hulk tighten it...I've had a couple break from that.
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
They make sleeves that go over the battery terminal to increase its size.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
167
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
563
Ffej
Ffej
Wichita, KS
10k-watts
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
