Custom Big 3 kits in OFC and CCA
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
Email at Ryan@RAM-Designs.com to order with your measurements ready please. I DO NOT RESPOND TO PM'S.
1/0 Big 3 kits using black Audio Technix CCA and OFC wire. FIRST 10 ORDERS GET A FREE AUDIO TECHNIX DECAL!
These will be made using Audio Technix CCA and OFC wiring, which is some stout wire for 1/0...barely fits inside the 2/0 ring terminals I am using. The ring terminal bolt hole can fit a 3/8" bolt. The connections will be crimped via a hydraulic crimper to ensure that the wire will never come loose. The connections are then heat shrank with adhesive-lined heat shrink tubing that will not budge once shrank. All in all, it makes them look very clean, and the black on black look keeps it stock looking as well.
$49 shipped for CCA
$69 shipped for OFC
Included in price.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
adamrali
