COMPLETED Custom built 15” sub Dual 2 ohm
  • 1
djdilliodon!
763
NY
Price
$150
Condition (1 worst - 10 best)
8
This subwoofer is built using a Dayton max X motor and everything else has been changed. It has a 2.38” dual 2 ohm copper coil with an increase in winding length for additional xmax. Non pressed paper cone with tall surround. Dual layer spiders with flat woven leads (spider has spots with glue on it, it was an extra one I had laying around I once got glue on but since it fit I used it anyway, doesn’t have any negative affect), direct 8 ga leads, upgraded cast frame, and real carbon fiber dust cap. It will handle 800-1000rms, I’ve run 1200 rms without issue in a sealed box which is 2.7 cubic feet internal volume. It will also do extremely well in a ported setup (it excels ported actually) using a box that is 3.25-3.75 cubic feet of internal volume. First $150 shipped gets it!
Was Photo Included
  1. Yes
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
djdilliodon!
djdilliodon!
NY
djdilliodon!
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
