Custom built RE 12's
Purplehaze-
Custom "RE" 12's
New builds, unused, never seen power.
$230 shipped for the pair, (cont.US only) or 130 each shipped.
These were 15" RE SRX motors, old ones, with the stamped steel frames. They were drilled and tapped to take a standard 6 bolt pattern, then paired with 12" 12 spoke frames w custom paint. They have 2.5" coils, and were built with SA12 soft parts. Black paper dust caps. Dual 2 ohm coils, stitched leads, 10g terminals.
Not really looking for trades, but it never hurts to ask. These are cool subs and will make someone very happy.
Yeah, sorry about that. I added it to the original post. 600 RMS, may take more in the right set-up //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Also, here are the ts parameters I came up with. They will most likely change after break-in. Most manufacturers test with subs that have at least some break-in time, these have had none.
* This data was exported from DATS the Dayton Audio Test System
* Manufacturer: Trent Stover (Purplehaze)
* Model: RE SRX 12
* Piston Diameter = 254.0 mm
* f(s)= 37.01 Hz
* R(e)= 4.28 Ohms
* Z(max)= 25.32 Ohms
* Q(ms)= 3.987
* Q(es)= 0.812
* Q(ts)= 0.675
* V(as)= 26.910 liters (0.951 cubic feet)
* L(e)= 4.97 mH
* n(0)= 0.16 %
* SPL= 86.15 1W/1m
* M(ms)= 247.80 grams
* C(ms)= 0.07 mm/N
* BL= 17.44
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
Purplehaze-
Purplehaze-
Hell's Half Acre
Purplehaze-
