SOLD Custom made 12" sub box! GMC/chevy truck 99-07
04blackgmc
IL
150+shipping!
fits a 12" sub ALOT of time and effort went into this and fits like a GLOVE!
box is about .88 cu ft.
here are the specs of the sub in it.. still has a little extra mouting depth
i think somewhere around 6.5 i thought..
here is the specs on the current sub in there and there was a little more room left..
Size (inches) : 12"
Z (ohms) : 1.0
Xmax (mm) : 7.3
Fo (Hz) : 26
Bl (T.m) : 7.2
Vas (liters) : 110
Qms : 5.50
Qes : 0.42
Qts : 0.39
Mms (g) : 136
SPL (dB/w/m) : 88.5
Levc (mH) : 0.57
Krm (mohms) : 1.58
Kxm (mH) : 28.7
Erm : 0.83
Exm : 0.57
Freq. Resp. (Hz) : 25-2500
Power (max/nom) : 480/240
i am selling this thing pretty cheap since it cost about 100 in supplies to make it..
the bottom is 3/4 MDF sides are 1/2 and the rest is all fiberglass...
can get more pics if needed just took the system out tonight.when i mean glove i mean it too. Thing had NEVER moved once in the past year or so. To get it in and out you actually have to take all the seats out and Center seat.
sides are 1/2 mdf and bottom is 3/4 the rest and all the shaping is all fiberglass and matting.
Built the framing then layed fleece and fibers many many layers atleast 3 on inside and then 3 on outside...
Then filled the inside with undercoating.
Layed 1 layer of mat down also.
Outside then got a layer or 2 of bondo glass.for the first shaping..
Then a few layers of bondo and alot of shaping.
Then coated the whole box in undercoating.
Think that sums it up.
sold the truck on ebay guy is picking it up next weekend and i am getting a 04 gto 6 speed if everything works. so im parting out what the guy didnt want.
need an enclosure for that? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
04blackgmc
04blackgmc
IL
04blackgmc
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
