dayton DSP 408
fyi....i cant remember exact voltage but it was around 3 volts before the rca inputs clip on the Dayton DSP 408 ( verified with DD-1) i got rid of mine because of this
Yes 3.2 volts I think is the input max
i will be measuring the head unit voltage to get a max volume available
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
OK, I am not the person to ask about SQ. Yes, I know a fair bit. Yes, I can offer quite a bit of opinion and fact on amps/speakers/etc. My entire...
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
Jimg
CarAudio.com Regular
Jimg
Jimg
