Dayton dsp help
  • 3
Jimg
CarAudio.com Regular
217
13
Here is the setup I am looking at unless someone has a better solution
car is a 2012 mustang
Shaker 500 factory radio
1st. I am removing the factory radio
Probably goin to use Kenwood or pioneer double din. I need the double din to add a back up camera
2nd. I have a set of 5 1/4 focal components I was going to make a template so I can mount them both the speaker and the tweeters in the factory speaker location in the top of the door
3rd. I have a set of focal 6 1/2 component. I am going to make a template and mount the 6 1/2 in the factory sub location in the bottom of the door
but here is where it gets where I want a little direction
I want to mount the second set of tweeters on the dash in the pods that came with the focals
if I do this this will take all 8 outputs from the dsp 408
4th. My thought would be the dsp to control the 8 speakers up front
then just use the sub out put from the head unit with the built in cross overs
Is this option ok. Or are there better options for wiring this setup
5.25 are going to do anything great for your front doors . Which focal series is the 6.5 set. Run the 6.5 focal set active on a network capable double din and a four channel amp. You won’t even need that dsp.
I already have the speakers purchased and the dsp
Focal. Iss 130. 5 1/4
Focal. Iss. 165. 6 3/4
Dayton DSP will **** on any headunit DSP.
I wouldn't run two different sets of speakers though. Going to get cancelation issues.
Just run the 6.5s active or go with a 3 way active setup.
totally right on the dsp vs headunit but factoring an overall upgrade from factory headunit, the new headunit dsp run active on the 6.5 comp set
Might be a desirable enough improvement. Could always add the Dayton dsp if it wasn’t good enough
Forgot to add. Will be running two 8 inch subs ported
Or one 10 inch sub ported in the trunk
OK, I am not the person to ask about SQ. Yes, I know a fair bit. Yes, I can offer quite a bit of opinion and fact on amps/speakers/etc. My entire...
8
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
4
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
6
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
4
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
7
Jimg
Jimg
Jimg
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
