DAYTON HO 12 dvc.
your gonna get good balanced sound and wide range of frequencies, listening to rock, metal, jazz, electro, hip hop, country will all sound nice, it wont do hair tricks or flex 2 inches on your glass windows(but there will be flex depending on your box quality) but it'll sound hella nice with a decent punch, i'm using one of those as a home theatre sub and it kicks the crap out of my polk psw 505 12" in SQ and loudness.
I just bought the 8" HF.
HO is high output
HF is high fidelity aka faithful sound reproduction aka sound quality
But I'm sure with Dayton either one is going to sound pretty dang good
Dayton HO is generally the better of the 2 for a car install as the box size for the HF gets a little big for what you get back. Best way to run the Daytons is a small ported box tuned low. That helps deal with the lowish xmax and the frequency response doesn't really take a hit, IMO, it'll sound a bit more natural, unless your in a very small car.
Take a look at this review with pictures and all:
Dayton Audio RSS315HO-4 12" Reference HO - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Regarding the box setup, most people who use Dayton HO subs, like them because they get good qtc in a small sealed box, which is useful in a lot of car installs. However, I remember that some people did try Dayton HO subs in ported box (as well as IDQ v3), and they liked it a lot too. It's up to you. Building a good ported box is more hassle, but one clear benefit is that you can get away with just one sub, instead of two, if you care about not adding too much weight to your car.
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
4
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
6
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
7
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
4
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
HoovaDeuce 82
Ft.Worth, TX
zako
