Dayton Subs: Titanic vs. Reference HF
td5turbo
a room
So I have decided to run a Dayton 12" sub. I have been wondering what the difference between the Titanic and Reference HF (HO?) are. Is the titanic more towards the SPL and less SQ or something?
Its probably going into a sealed enclosure with a Pheonix Gold 400-500wRMS amp.
Just looking if the HF can give that nice loud sound but be clear or if the HF is more towards that crisp clean bass.
Just looking at what the pro's and con's are of each sub. Thanks!!!!
They're both very similar drivers but the Titanic will get louder and the HF will have better upper frequency extension. They're both great sounding drivers and will do awesome in about 1.5 cubes sealed. I loved the sound of the Titanics and think they're great drivers for the price. I only heard the HF in about 3 cubes tuned to 22hz I believe so I can't compare their low frequency extension.
So your saying one single titanic will probably be louder than the HF?
But is the titanic a more SPL driver than the HF? Would I be able to notice a difference in output? If so, is the lack of SQ worth it?
neither driver is anything remotely close to an SPL driver and your application will dictate which is better. I'd get the titanic for car based app, but that's me.
Those are terrible terms that I don't like to use to discuss drivers. Both drivers were very clean sounding and it would have been difficult to distinguish on from another when listening to music at the same level. The HF did have a noticeably better high-bass extension and the Titanic was a little louder all around (minus sub 35hz stuff as the HF was ported and could dig deeper there). If both subs were sealed, I would say the Titanic would have a noticeable edge in output but both drivers would sound very similar. And no, you wouldn't be loosing any musical accuracy going from the HF to the Titanic.
Well, with that said, looks like I will be running a single 12" Titanic in a sealed enclosure off a 500wRMS Pheonix Gold amp.
hmm, but what about a two 10"/12" Reference HF? haha, choices, choices!!!
I went from a single 12" HO to a 15" XXX, and now I'm going to 2x10" HOs.
If that means anything to you, basically I enjoyed the HO more than my XXX, go figure right?
The HO requires a very small sealed box, for the 12, .8 is what I would recommend. The only reason I swapped from my HO to the XXX was because I destroyed the HO by using too large of an enclosure, broke the former right off. However, thermally the coil was fine, even after abusing it with my 2.2HV.
Oh, and the 10s will be going in a ported box tuned to 30hz, each driver will have a chamber of about .67 cubic feet, and again powered by the 2.2HV. I need one more sub, which should be here from partsexpress by the end of this week, and I'm having a buddy build me the box, which should be here probably by next week at the latest.
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
6
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
4
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
7
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
4
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
td5turbo
td5turbo
a room
ThatChevyGuy
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
