DB Drive a7 2000.1 "Nothing else"
Whats ur final impedance when u strap both A7's?
Well 2ohm is its rated lowest load when strapped but will be wired down to .67ohm "thats before rise and all so real world 1.5ohm"... No worries I know these amps can do it all day. Local guy has his wired at .25ohm...
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
I didn’t want to mess with my daughters EV, so I just made a small stand alone with 6x9s. It’s around 75 watts rms and fairly loud actually. Real...
8
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
disturbed471985
disturbed471985
Greenwood, La
sandmanll06
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
