dc 2.0k with a 300 amp fuse
  • 2
Will this work or is it to much on their website it says 200 rating but i dont have a 200 amp fuse, if so could somebody tell me any local places that have inline fuses or sell 200 amp fuses?
Probley any audio shop. Seen them at bestbuy to. And seen mega fuses at autozone
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
463
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
180
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
384
Agoonygoblin
Agoonygoblin
Columbia, SC
frogcase2002
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
