FuckPeteCarroll
Why do some amps have the two white bars on them while some are all black? Are they a different series or are the all black ones just older? Thanks
YesSo it's a bad idea to drill the amp to the box when I'm running that much power???
How much of a distance must be maintained from subwoofer enclosure for these amplifiers?The 9k is more power just keep either amp away from vibrations
if you didnt know this by now your not ready for a "huge" system..... just saying!!So it's a bad idea to drill the amp to the box when I'm running that much power???
That depends on your build. But a nice amp rack behind the box or even under the box can workHow much of a distance must be maintained from subwoofer enclosure for these amplifiers?
Ah you mean the custom shelf some people bed their amps in above the spare wheel right. Yes, that's what I've seen many do so I was surprised when you advised to maintain distance but you meant just not right next to it then...That depends on your build. But a nice amp rack behind the box or even under the box can work
