DC Audio level 4 wiring Q
im buying a DC audio level 4 15" w/ 1.2k amp soon and am pretty sure i know the answer to this but i have a debate to settle with a not so knowledgeable friend and wanted to make sure: originally, it runs 1400 watts @ 2 ohms per voice coil. if i run the coils in parallel to the monoblock, does it then work 2800 watts @ 1 ohm or stay at the 1400 watts.
ill be showing the "friend" this post once it gets replies
thanks!
a sub doesn't run wattage. That is up to the amp to run power.
The sub (sounds like a dual 2 ohm) is slated to handle 1400 rms (each voice coil rated at 700 rms) total
That sub will handle 1400 rms no matter. If you get a dual 2 ohm sub, you can run it at 1 or 4 ohms and no matter what you run it at, the total rms power will always be 1400 rms
So to answer your question in your terms, it will stay at the 1400 watts
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
I had a JL 600 what amp (XD600/1V2) and the JL Audio Remote Level Control Knob (HD-RLC) installed professionally and hooked up to a JL Sealed 10in...
A Link would be very helpful. Id be interested in taking a look at some gear
55
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
222
CallMeRockford
CallMeRockford
Lincoln Park, NJ
CallMeRockford
