DC Level 4 or XL?
  • 4
brapbam23
I need help deciding what would be best for how much power I have.
I have a US Amps AX2000's.
600W X 2 @ 4Ω
1000W X 2 @ 2Ω
2000W X 1 @ 4Ω
Now I am wondering if I should overpower the Level 4 or under power the XL. I have the option to get the Level 4's with XL soft parts as well.
Level 4: 1400 RMS/2800 Peak
XL: 2200 RMS/4400 Peak
Any advice is helpful. Thanks
lol.. You really don't have enough power for a level 4. So out of those choices a level 4 would work. Are you powering two subs with that lil amp? If so, and if you pay for new subs, then you might want to get a spider removed to make them for efficient.
I do have 2 used level four 12's dual 2 ohms if you are interested as a option.
lol.. You really don't have enough power for a level 4. So out of those choices a level 4 would work. Are you powering two subs with that lil amp? If so, and if you pay for new subs, then you might want to get a spider removed to make them for efficient.I do have 2 used level four 12's dual 2 ohms if you are interested as a option.
I am powering one sub with the one amp.
If your gonna buy new, then you mine as well get the coil upgrade...I would not however get the XL spider upgrade as it would be too stiff. I would get the reg level 4 spider pack/ soft parts.
Factory. 2021 Chevy Silverado custom trailboss
9
682
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
720
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
624
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
brapbam23
brapbam23
Mojave, CA
vetkilr
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
