DD9910 how many cubes?
  • 6
cha0
Im extremly limited on space and power but already have a DD 9910 laying around. I need to be under 2 cubes with 1200w so im thinking just go sealed. If I want a decent mix of spl and sq, what size box should I go with for a dd10 and and 1200w?
I have roughly 1.5 cubes to work with.
thanks guys.
What letter series? Must be old, because they haven't made a 10" sub in the 9900 line for a while. Generation/version would help determine box recommendations.
Its actually the first Audioque 10 ever made. Which if you remember, was made with the same motor, masket, etc as the 9910 that was being produced at the time and even shipped in a DD box. The first AQ drivers were made in the DD plant until the business was completly split by DD family members. It was literally a 9910 with a SQ sticker on the dust cap.
hope that helps some. Its like 12 years old now.
Cool, if you have any pictures, I'd like to see it!
That doesn't show sealed though. You'll have to take into account port size ansd stuff to see if you actually have enough room net after all the displacements and port stuff.
This morning I took actual measuments. If I take up every inch of my trunk I can make a box that is 1.8 cubes before disp. So I could probably be right at 1.5 cubes with an aero port.
This forum is a slippery slope for me. As of last week I was just going to run 1 10" on like 1200w.
Now I think im going to just go for it and throw a mean green HO alt in and go with an saz-3000.
Any final thought 1.5 cubes, tuned to 35hz, 1 10", saz-3000, mean green alt yellow top and big 3?
Havnt had any system since my son was born 7 years ago. This is going in our project jeep. Might as well do it right. Good by trunk...
Everything good except the yellow top. Plenty of better AGM's out there that will cost less and last longer.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
cha0
cha0
Chicompton
cha0
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
