Design Questions for 12" Rockford Fosgate P2D2-12 in 1.79 Cubic Ft
Decifer
I need a design for a enclosure with 1.79 cu. ft. internal. I was hoping for some suggestions on the position of the sub and port as well. The amp I will be running is a Rockford Fosgate Punch 360a2 (Rockford Fosgate Punch 360a2 90 x 2 Car Amplifier at Crutchfield.com)
Im pretty sure I am going to go with the Rockford Fosgate P2D2-12 (Rockford Fosgate P2D2-12 Punch P2 12" subwoofer with dual 2-ohm voice coils at Crutchfield.com) but wanted opinions on Rockford Fosgate P3D2-12(Rockford Fosgate P3D2-12 Punch P3 12" subwoofer with dual 2-ohm voice coils at Crutchfield.com) What sub would best be suited with the amp?
Either way both subs have the same ported enclosure specs. Ill be wiring the sub in series for a 4Ω mono load.
Vehicle : Dodge Magnum
Location in the vehicle: Back hatch area
Space available (Length x Width x Height): Any x 38.5"max x 15"max
Subwoofer make and model: Rockford Fosgate P2D2-12
Subwoofer Size: 12"
Number of Subwoofers: 1
Type of Port: Slot
What type of music do you like?: Everything but country, Mostly Metal
Is your goal SPL or Everyday Music?: Everyday music
Tuning Freq (Hz): thinking somewhere between 32-34
Volume : 1.79 cu. ft.
Get more solid bass drum punch, especially double bass, from a sealed.
ported's always given me better sound with metal particularly because it is much louder and depending on the box design it can sound just as good as sealed. Sealed is soo quiet I cant stand it. Whats the use of listening to metal if its not blowing your brains out?
a design from Moe lester
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
3K
Not sure if this is reliable but trying to figure it all out on my own at this point. Does this look good?
779
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
738
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
Decifer
Decifer
Pilly , PA
CSCStang
Decebal
    Jun 10, 2024
