Detailed Alpine X-A70F Specifications
  • 1
fireplace369
Hi. I'm looking to find out some very detailed specs on the Alpine X-A70F amplifier.
What I'm looking to find out is roughly what the true power output is per channel at 4 ohms (birth sheet gives highest power output at lowest ohms), what its true efficiency is, and its maximum current draw for a 4 ohm load.
Any help is greatly appreciated. Thank you.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
191
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
437
So far I have bought Kicker CWRT8D4 Subthump underseat enclosure for 8 LoopBack Harness from AIS 8 gauge Kicker wiring kit (Will run two 8 gauge...
13
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
fireplace369
fireplace369
New Hampshire
fireplace369
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
