diamond audi/power?
TypEL
hey guys just got my diamond audio s600s comp set.
first question is how much power (rms) can they handle w/o distortion or blowin up heh
second im using a eclipse 32440 amp..its a 4 channel
im only using 2 channels though...rated at 85x4rms at 4 ohm or 120x4rms at 2 ohm
since my comp set is 4 ohm speakers..i know i can get a 4 ohm load.............but wat if i use all the channels and bridge them..channel 1-2 for 1 side and 3-4 for other side bridging
will that get me a 2 ohm stereo load....and will the diamonds take 120 rms per side?
if i understand correctly....not only will you be bringing it down to 2 ohms...but also bridging, which means 240 to each side.
i have the same set of speakers as you, i'm running 75watts to them and they seem to shine very well. i have a 4 channel amp (75watts x 4 @ 4 ohm) and rear speakers, but i'm getting rid of the rears soon, and when i do, well, i'm gonna have to utilize the 4 channel amp the best way i can, bridge it to the HEX's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i'll be running 300watts a side when i bridge it, i'll let you know how it works out.
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
11
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
4
676
Need more info. What is the year of the auto, what is the stock system, and what equipment are you trying to put in its place would be a good...
One thing I’ve noticed about reading reviews is those who cannot spell offer very colorful and misspelled adjectives to describe products. Take...
I am in the same situation as you. I am thinking I’ll have to get a line out converter. That allows the use of the factory head unit and add in...
8
TypEL
TypEL
Vancouver,BC
quiimari
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
