Diamond audio D5 300.2 amplifier
  • 2
Tallc
tx
Diamond Audio D5 300.2 amp
NEW in box
$80 + shipping
+ shipping
• Fully Regulated Power Supply
• Up To 5V RMS Input Signal Voltage Capability
• High pass x-over 12 dB/oct. 1.5 kHz-15 kHz Subsonic 15-1.5 kHz
• Adjustable Q with a 10 dB boost
• Low pass x-over 12 dB/oct. stereo 50 Hz-5 kHz, mono 24 dB/oct. 50 Hz-5kHz
• RCA Outputs
• 2 oz. Silver Plated Copper Circuit Board
• Massive Proprietary Heatsink
Convenience/Appearance
• Fully Variable Electronic Crossovers
• Nickel Plated Solid Brass, Circuit Board Mounted, 4 Gauge Direct Power/Ground Connector Blocks
• Nickel Plated Solid Brass, Circuit Board Mounted, 10 Gauge Direct or Banana Plug Direct Speaker Connectors
• Fly Cut Billet Aluminum End Plates
• Fully Adjustable Mounting Feet
SPECIFICATIONS
Frequency Response: 10 – 50,000 Hz
Signal-to-Noise Ratio: 100dB
THD: 0.03%
Channel Separation: 80dB (min.)
Input Sensitivity: .2 to 5V RMS
Input Impedance: >20k Ohms
Power Supply Operating Range: 11 to 14.5V DC
DIMENSIONS
Length: 12 1/2"
Width: 12"
Height: 2 3/4"
CONTINUOUS RMS OUTPUT POWER
Note: Full Rated Power is generated at all voltages between 11 and 14.5V DC.
75W x 2 @ 4 Ohm Stereo
150W x 2 @ 2 Ohm Stereo
300W Bridged @ 4 Ohms
(minimum impedance)
CROSSOVER SPECIFICATIONS
Quantity: 1
Type: Fully Independent and Adjustable Highpass, Lowpass,
and Subsonic
Slope: 12 dB/Octave Stereo, 24 dB/Octave Lowpass Mono
Alignment: Butterworth
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
11
A Link would be very helpful. Id be interested in taking a look at some gear
218
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
341
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Tallc
Tallc
tx
Dirtrider4eva
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
