Diamond D1000.1 problems
  • 3
midwestmusic
NEBRASKA
When I turn my stereo on, the D1000.1 just sends my sub a solid weird sounding note, not connected to the music being played. Could this be the gain is set incorrect? Im pretty lost. The sub is an Obsidian Audio D4 which is wired to 2 ohms, the amp can handle a 1 ohm load so I just dont know. Appreciate any knowledge of what is going on. Thanks
Sounds like a bad ground or an RCA issue. Check all your connections and do you have any other RCAs you can try out?
Thats bizarre. I posted exactly the same thing right after he posted and it never showed up
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
11
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
942
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
869
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
midwestmusic
midwestmusic
NEBRASKA
midwestmusic
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
