Dick wont work now?
hdj20
F*CK SONY
784
wisconsin
Hey just put in this deck and their was some exposed wires which ended up blowing the fuse for the radio. so i replaces it with a spare that was in the box. the deck did have powere before the fuse blew. why wont it work now with the spare fuse in?
might have fried it...
what wires touched? did you check if you were getting power to the radio? it's also possible you blew some fuses in the car along with the deck...
im not really sure just know it blew the radio fuse so i put the spare in, would the other fuses have an effect on it? the radio fuse still looks good.
I dont want to help but i know my lover had to have changed your title. DBfan187 is my lover //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
no homoz
do you have a multimeter?
Only thing you can really do is check the fuses in the car, then, which is most likely the issue imo. Just would be a lot easier to identify the problem and fix it with a dmm.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
That's the dd1 The dd1+ has only 4 tracks. I have the dd1+ , just got home. I think the dd1 has all those other tracks. Diff tool. So it says...
9
Id remove it at this point and bench test it on 12v
6
hdj20
F*CK SONY
hdj20
wisconsin
TMali
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
