Do 6 and 12 spoke 18" baskets share the same mounting hole size?
  • 1
manyhobbies
I believe the 6 and 12 spoke 18" baskets share the same cut out mounting hole size but I havn't confirmed this as of yet, so can someone confirm this. I have 6 spoke baskets to measure off to cut the holes for mounting but I will be putting 12 spoke basket subs in and dont want a sloppy hole and what I mean by this is I dont want any play in it. These are the standard common traditional baskets.
From what I measured it appears to need to be 16 5/8" with the gasket. Thanks, Russ
  • Locked
Negative 1aespinoza . The spider landing is to big on the newer 12 spokes like you posted . I need the old school 12 spoke. Nobody here has...
3K
manyhobbies
manyhobbies
Celina, Ohio
manyhobbies
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
