Do I need a L and R RCA signal going to amp for 2 channels I'm bridging?
  • 4
seatown1two
Title pretty much says it all. Will be taking sub signal from the factory headunit and there is only one positive and one negative wire which will result in one output. The signal is for a sub that I am running off the rear channels (bridged) off a 4 channel amp.
Thanks in advance..
Thanks in advance..
You will only have one working channel if you are using 2 bridged channels total. Which means only one channel would be playing.. You can always use a Y splitter though
you wont have as much output even with a y splitter since youre using a 4 channel
Signal is first going thru a line driver before the amp, does that make a difference? What would you recommend I do? There is a setting on the amp to use the inputs for channels 1 and 2 but the reason I want to use the sub signal is so I don't lose the functionality of the sub volume control on the head unit.
get a new HU
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
984
Have you spoken with one of the reps? They should have all that info on file.
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
642
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
422
seatown1two
seatown1two
Edmonds, WA
maylar
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
