Do I need a second batt
macsdad
boom-boom
Ok, my oem alt is taking a dive, I have a ho alt to replace it with. My question is; Do I have to add a second battery when I install my ho alt? If I don't install second battery, will the ho alt damage anything in my electricals? Thanx in advance.
You don't have to add a second battery if its not needed. But chances are if you are needing to add a HO alternator than you probably need an extra battery. The alternator wont damage anything without adding additional batteries. Alternators regulate there amperage output. It will only put out high amperage if needed
I have to add the ho alt because the oem is pooting on me, what's up jim? Thanx for the responses guys.
Not much man. If you have the stock battery you might wanna get a agm but that depends in your batts age to Do fix it if it ain't broke
Naw I have a red top under the hood, so I should ok, right? I do have a small xs agm I got from mylows just in case. Again, thanx guys, enjoy your judgeship this wkend jim. If we need your help, I will a reachout. Y'all have fun, ya hear!!
My usual order of electrical upgrades is:
-Big3
-Make sure you have sufficient size wire and solid ground to amp
-Deep cycle battery to replace stock battery
-Add 2nd same type deep cycle battery in rear
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
318
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
692
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
448
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
499
macsdad
boom-boom
macsdad
Trussville, Al
ngsm13
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
