Do i need to be carful with gains if sub and amp match??
Retrofuture30
CarAudio.com Recruit
Nood question here do I need to be careful where i set gains if my sub and amp have the same watts rating? Can i just sit gain dead center? And not blow anything if played at high volume?
I didnt really hear no distortion when i played 50hz tone with gains up.
Heres the smp ans sub i got. Yes i know they not 2300 watts, realistically should be 650watts.
any advice appreciated, first day messing with car audio
Yes, especially at this price point. There are so many variables that can go into this, its really really difficult to point you in the right direction.
First, you linked the RZ5--2500D which is the 5 channel amp instead of the RZ1-2500D which is the Mono subwoofer amp. Which one specifically do you have and how do you have it wired? 2 or 4 Ohm?
Second, what Head Unit are you running and what pre-out voltages does it provide? 2V or 5V?
Third, what car/alternator/gauge wire do you have going to the Amp? (Provides an understanding of the quality of signal going to amplifier and electrical headroom to support the amplifier draw)
Fourth, what type of box are you using? Sealed/Ported/Cu.Ft?
You're most likely not going to be able to overdrive that Subwoofer based on wattage alone, the sub is rated at 1200 RMS vs the 600-650 RMS that either the RZ5 or RZ1 amplifier can produce.
The most likely scenario at this price point is you'll cause the Amp to "clip" where the amp reaches maximum output capacity but keeps on trying to keep up with the gain ratio set, to do this it will cut the waveform which is identified as clipping. When an amp starts clipping an output signal all kinds crap can occur - Overheating, mechanical failure, protection mode etc.
In a perfect world, you're giving the Amp 4/5V preouts, with clean power, turn off all EQ/Bass Boost and measure a 40/50hz signal with a DSO Nano. Set gain based off of a clean sine wave. Gain level changes depending on all of the other conditions mentioned. Less optimal way of verifying is using a multimeter to measure VAC output to RMS rating. (V²/R=Wattage) Once you know your gain is set properly/not clipping then you make sure your sub box matches the recommended enclosure specs, this protects the sub from reaching mechanical limits and maximizes the sound it can produce.
I'm going to assume your Amp's RCA's are wired in from LOC's correct? Do you know what LOC's were used?
Electrically, I'm going to assume you've got the headroom with a Yukon Denali, depending on year and options it should have a good AD244 on the older ones or an even better 8302 on the newer ones.
I don't want another flame war but that box will leave a lot on the table as far as SQ is concerned. Most here despise prefab, for good reason. They tend to be tuned high and not well made. Something you built yourself tuned correctly can make $50 sub sound like $500 and a prefab box can make a $500 sub sound like a $50 one. Just food for thought.
Still recommend grabbing a multimeter and testing VAC output on 0db test tone or picking up a DSO Nano and measuring output signal to make sure there is no clipping at whatever max volume you listen at.
skip all that multi-meter nonsense because you dont know what the actual clean amount of power than amp has because power acoustik doesn't do rated or anywhere close so you dont even know what number to shoot for. Play your hardest hitting song, raise the gain up till its not getting louder, now lower it a notch or two. Check for heat on the sub's cone and amp when you play for a minute to 10 minutes, keep checking up on it. If its warm and getting warmer, lower your gains slightly until its room temperature to slightly above room temp.
You can also do a little 3 dollar piezo tweeter method like this which is far more reliable than a multi-meter
yes its wired thru rca, I have no idea what loc was used. Had it wires last year and just hooking it up. Yea i wanted a better bigger box dont dont have the space with third row up. Ill be adding a real system in my 2nd non family car.
Ill try the multimeter this weekend and see how it goes
Tried the multimeter and it only goes to 26.2 volts playing 50 hz tone and i need to get to 50.00 volts.. what the hell?
So turn gains all the way up? (The sub is 2x higher then amp)
read my comment earlier. Multi-meter method completely useless in your situation.
A guy on youtube did a dyno on this amp. This the P.A amp with correct wattage. I also tried your method and turned 50hz tone up loud as it can go and put gains all the way up and it didnt distort. Just get stronger at same tone.
would you try just setting gains over half? Since no clipping?
dont use a tone, use music your hardest hitting song. You are listening to music not test tones. Test tones are only valid if you actually analyzed the recording levels of each song in your music library and you generate a test tone that matches the recording level, not some random ass 0 db test tone you find online that will literally just give you a super innacurate setting.
Power acoustik has pretty poor quality control so the actual power output of each amp can vary. Just a thought.
Since you are using a stock head unit, you are using an LOC right? raise the level adjustments on that a lot higher and lower your gains then restart the tuning process.
See if you can find a little piezo, wire that up with your sub at the same time, The impedance is so high it wont really affect the sub the buzz noise would be clipping. very fast easy method.
Where are you at in Louisiana?
Ahhh i got you. Ill try with hard hitting music tonight. Ill look into piezo also
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
251
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
669
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
433
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
486
Retrofuture30
Retrofuture30
Louisiana
1aespinoza
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
