do i need to upgrade my alterantor and/or battery
Install it and keep an eye on your voltage, maybe, maybe not youll need one only way to find out is by trying it. For the most part pwople atart HO alts after maybe 1500w thats hifonics only does like 2k rms at 1 ohm And at 2 it probably does 1k clean. So if you set your gains properly and dont clip i dont think youd need amy upgraded electrical
It's more of a long term problem than short term.
Short term it should work fine.
Naturally, there will be voltage dips at high demand, but that is to be expected (even HO alt's can't respond instantaneously).
The problem is the overall work load for the alt will be much higher than before - so it will run hotter more often.
That will shorten its life.
How much shorter it will be depends on your listening habits and the initial quality of the alt.
When the stock alt fails - whether that's next month or 5 yrs from now - you can decide at that point if you want to replace it with HO or stock.
I've always gone with stock and just planned to replace it every 18-24 mo. Although my current stock alt is 160A and seems to be holding up well with 1500w of power (but I don't blast it very often).
That is a seriously strong amp. I suggest you get it done by a pro. If you already tried it and it works, it might not be the same after some time. For the electrical system you will observe a slight drop on the voltage when playing in full tilt, but that’s fine.
Regards,
Sevgi S.
Blog
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
they don"t have anything for the G8, and my problem with the install kit is the hvac part. i dont like the physical controls on it, hard to operate
Not that I like shilling my own sales but I have a badass digital designs 5channel for sale in the classifieds. One of the largest available...
jakekruika
jakekruika
Wilkes-Barre, PA
sevgi
