Dodge Avenger Big 3 Help
  • 3
Bassically85
Hello guys, I need some help...
In my 2008 Dodge Avenger my batter is in the WORST place, behind the wheel, so there are terminals which allow you to get to the positive and negative terminals without having to take the tire off to get to the battery.
My question is do I have to replace/ go along side the access terminals when I do the big 3?
Dont replace, just add
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
4K
Bassically85
Bassically85
Atlanta, Ga
furbee86
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
