Dodge Dakota Simple Install
  • 4
LiveAudio911
Texas
Thought I'd share my final build out... I built the box some time ago for my old car so I just reused it.. So not too much of a build out.. Just putting it all together.
Right now I have planned for this to be a temporary build.. as I want to build another Custom box, vehicle specific this time //content.invisioncic.com/y282845/emoticons/santa.gif.e1ec9cf2e0a0dd232ad35aa594a126d0.gif
Current Build:
JVC Arsenal HD Radio
Boston Acoustic 6.5 2way (Already in the truck)
No rear speakers
0/1 Ground Chasis from block
2 ga from battery to chasis
2 ga from battery to amp (5 ft)
2 ga from alt to battery
Stock 1080 CA/800CCA battery
2 JBL P1224's Each in sealed 1.35 Chamber
JBL GTO 1400.1 running @ 4Ohm 1200RMS
Future Plans:
Build Custom box vehicle specific (Thinking of entire rear cab...)
Replace Boston's in the door with my GTI 6.5 Comp set or ????
Customize Rear speakers for custom fit ?????
(Still debating)
Install 4-ch Infinity 475a
Still debating.. Subs are hella deep and tight.
Yes, and 1500 @ 2
Going to customize it.. just not sure what direction to go yet.. after seeing the build out of Memphis Dakota RT>. gave me some ideas.. ^)^
If you mean because of vibration.. that amp has been mounted on that same box for about 1~1.5 years.. i forget the time i've had it... but... def.. got the ballz to hang together..
But def want to do something different that looks good with the custom box I want to build..
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
4K
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
LiveAudio911
LiveAudio911
Texas
LiveAudio911
Decebal
    Jun 10, 2024
