Dodge Magnum 2005 speaker wiring problem...
  • 1
zeighty
Hi all - New to this forum, but hoping the experts are ready to answer a puzzling problem.
Company car stereo lost sound in both front speakers and left rear. Right rear continues to work.
Purchased new head unit. Made all necessary connections to wiring connecters and soldered all connections. Plugged unit into car wiring, turned on, tuned station, turned up volume and no sound.
Troubleshooting with Crutchfield resulted in a new HU being sent to me. New unit same symptoms.
This time I only connected power and no speakers. Tested right rear output of HU to right rear speaker. it worked. When I connect any of the other three, the right rear went silent.
Here is what I have done so far to track this down:
1 - Shorted both rear speaker connectors to confirm continuity.
2 - Connected each of the rear speakers to the output of the HU directly and both worked.
3 - Checked each of the rear wires for continuity to ground and none found.
4 - When connecting left rear (right rear disconnected) I notice intermittent static from the speaker when only touching one HU output lead to only one speaker wire (I am thinking this confirms a short).
I have not pulled the front speakers yet.
At this point it sounds like a short in 3 of the 4 pairs of speaker wires.
Does anyone know the routing of wires for the speakers and is there a common point that 3 of the 4 could be damage all at once?
But because I have never seen anything like this before I thought best to present it to those of you with much more experience than me. I have done probably 2 dozen installs, so I am very familiar with the process, but I am sure many of you do this day in and out. I am a computer technician and a Ham radio enthusiast with at extensive electronics background (not car related though).
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
995
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
4K
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
zeighty
zeighty
Central Florida
zeighty
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
