Drivers and Cross overs.....
  • Thread starter <Muff Diver>
  • Start date
  • Replies 1
  • Views 1K
    Participant list
<Muff Diver>
Guest
Ok, Im stupid and I need everything explained to me. But im pourin money left and right into my car. What the hell does a driver do? What does a Cross Over do? And what is an "OHM"????
If anyone can explain these things it would be greatly appreciated.
A driver is just another term for a speaker. I have heard this term mostly used for mid-bass woofers, but have heard tweeters and subs called drivers too. There are two different types of crossovers. Electronic and passive. A passive crossover is usually a filter that helps block out unwanted frquencies to the designated driver. An electronic crossover can cut off the sound at a certain frequency. Both of the crossovers are used to cut/filter out unwanted frequencies from reaching a certain speaker. For example, a crossover would filter out bass frequencies from a tweeter, or would cut out higher frequencies from a subwoofer. Most amps have built in crossovers, most coaxial speakers have built in crtossovers and most component speaker sets have external crossovers. An ohm is a measurement of electrical resistance. For full understanding look up "Ohm's law".
The preamp input on most amps is 10-20k ohms, so you don't really lose voltage. I've run plenty of systems off 2v preamps with no problems.
5
981
Check out Focal. I believe they have direct replacements for many Toyota's...
4
Guest
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
