Dropped on coilovers
Looks nice, but IMO the front could come up an inch. The wheel arch is too close up on the tire. I assume you had to do some tweaking or cutting to keep from rubbing those tires.
Back looks perfect though.
Thanks man. Fenders are cut so no rubbing at all. I'm still playing around with the drop...you're right, as it is now there's a slight rake. If anything I might drop the rear slightly and tuck it a little more to get that "classic" drop look.
I've got 10mm Rogue Engineering spacers on the front...honestly I could probably get away stepping up to 15mm.
I like the stance, I just don't like the way the front wheel is tucked in so close to the fender. I like to have a good inch or so between the tire and the fender all the way around. Like the wheel arch is wrapped around the tire rather than covering up the top part. BMWs tend to have very good wheel fit, so you don't need to drop it as much as you would some other cars.
IDK, maybe it's just the angle. Get a good stright-line side view and I will reassess;)
CrazedCat
Right boot. Got it.
CrazedCat
NJ
Hintzyboy
