DSP diagnosis
  • 3
Leesi207
CarAudio.com Recruit
25
Maine
I had an Audison Forza hooked up in my car. I’m trying to determine the complete lack of midbass. Like there was much more when the car was completely stock.
When i fade to the rear on the stock head unit all sound completely fades out of the system.
When I fade to the right I completely lose all signal to my subwoofer.
is this typical?
is this typical?
1st you might think actual 40-60hz bass is midbass, but thats in the range of subsonic bass.
2nd stock speakers are tuned to play sub bass better than aftermarkets that boomy sound is actually sub bass, not midbass. So if you swapped them out, you'll be missing a huge chunk of your low end.
stock head units also have their own EQ curve, the DSP will fix the signal and provide a flat signal so all the stock head unit built in boosts that you cant change, well all that is flattened now.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
917
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
553
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
520
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Leesi207
Leesi207
Maine
Jeffdachef
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
