DSP for sub?
  • 2
To equalize the sub signal from an RCA input is a DSP the best/only option?
I have a Silverado with the Bose system. The bass was terribly attenuated so I used a PAC AmpPRO AP4-GM61 to get a better signal sent to my Fi Audio 12.
I now get 30 Hz and below but these frequencies are out of balance with the higher bass frequencies. Any recommendations for correction?
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
610
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
532
tank313
tank313
Los Angeles, CA
Jeffdachef
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
