dual 4 ohm sub with rub4.600 amp. what to do?
  • 4
dude
The RUB4.600 is a 4 channel amp. you can bridge ch1&2 to one 4 ohm voice coil, then ch3&4 to the other 4 ohm voice coil.
just be careful with polarity and use a DMM to set the front and rear gains - get them as equal as possible (within a tenth of a volt).
The Biden administration on Tuesday backed down on a controversial proposal to direct the IRS to collect additional data on every bank account...
31
6K
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Nighthawk1192
Nighthawk1192
Sacramento, CA
got-one-eight
