Dual Amp question.
  • 3
NorseForce
Hey guys I just want to make sure that I am not damaging anything with this setup. I have zero experience with installing car stereos previous to this so I have a few questions.
I have a 2014 ford focus and I recently installed a powered sub JBL gt bass pro 12 . Alpine 610c and an Alpine KTP445U to power the 610c.
So what I did was install the 455u amp to power the front speakers and then tap off the rear speakers via line out converter to install the JBL sub, which has its own onboard amp. Is this bad for the powered sub since the RCA inputs going to the sub are already sending an amplified signal from the 445u amp because I am using a LOC tapping off the rear speakers? Is this bad for the sub and does it degrade the sound output from the sub?
Any insight on this will help. THANKS!
What kind of head unit are you using? Does it only have one set of rca pre outs? If so, get a set of "y" rca connectors (single male to dual female) and plug those into the head unit. From there, run one set of rca's to the jbl amp and the other set to the Alpine amp. You are sending way too much power through that loc.
The sub amp will be fine with that. The real question is whether the LOC can handle the power level from the 455u. Most of them are good for at least 40 watts, some will handle more.
Got it. I would tap that loc in before the Alpine then. That loc has a max input of 40 watts.Just splice the rear outs from the Hu to the loc and rear in of the Alpine.
You could conceivably adjust your fader to around 70% front and 30% rear and turn up the loc gains if you want to leave it the way it is now.
^^^ Right. Which means running wires from the sub amp back to the Alpine instead of tapping off the rear speakers. But for the difference (40w vs 45w) I'd probably just leave it alone.
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
163
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
470
NorseForce
NorseForce
United States
maylar
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
