earthquake amps?
usually 10 x fuse rating tells you what the amp puts out.these are the lower line earthquake amps ,i would say no.but i can find out ,one of my teammates works for earthquake
thats what i thought myself. i've heard almost nothing about earthquake audio but they have some pretty high end stuff on onlinecarstereo. the price for the amp seemed amazing for that much power so i piqued my curiosity
would he want to multiply it by 12.8 or 14.4 depending on his voltage...
typically its 70 amps to 1000 watts for a rough gesture, so by the sounds of it, maybe, but thatd be a far stretch.
Amps x voltage x amp. efficiency = Approx. Output
Example= 70 amps x 13.8 volts x 65% efficiency = 579.6 watts. This is only an approx. figure as all three numbers can be affected by various elements. For example, lower ohm loads will usually reduce amplifier efficiency.
Hopefully it is ok to post a "for sale" ad on here. If not, I apologize in advance. Fully serviced Earthquake PHD2 amp for sale. Asking $175...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
192
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
439
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Nighthawk1192
Nighthawk1192
Sacramento, CA
Spooney
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
